Not sure if I saw this here or not but this looks promising.
http://www.allforge.org/
Trying to get in contact with them to see if they have tested the High Temp resin in their machine… If this works I will buying one.
I looked at this a year or two ago. It’s a nice idea but I’m wondering if the pressures will be high enough.
The shot size is actually pretty good but we have no idea what the pressure is and that could cause issues (closing force and injection pressure).
There’s no reason why printed cavities shouldn’t work as long as they are placed into frames. The high temp is reasonably brittle and will crush without a metal support around the outside.
Cooling times may need to increase in order to keep the printed molds from getting too hot.
