I’m using Dental SG resin, but I’m not seeing the yellow -> orange color change that’s supposed to happen after post-curing and sanitizing. I’m not using a Form Cure, but rather a bio-safety cabinet with a UV light and then autoclaving. I assumed that the high autoclave temperature would take care of the needed post-cure heat. Any recommendations for how to get the color change without a Form Cure? Also, anyone know to what degree the bio-compatibility is hindered by a lack of color change? (NOTE: I am not using these prints for dentistry)
DentalSG needs light and heat together for a full post-cure, and the lack of color change likely means that the parts aren’t being fully cured. Parts that don’t reach the recommended curing specification cannot be guaranteed for bio-compatibility. There’s an instructions for use document on this page that you should check out for minimum cure specification.
