I am working on the cad cam designe from 3shape, formlabs doesn’t have pink denture base material bu Kultzer does inconjuction with thier cara print printer, my question is could I pour the Kultjer pink and tooth shade into formlabs injection tubes? thanks Mike
Are you just doing R&D or are you planning on a patient try-in? One printer is SLA and the other DLP so I’m not sure how the resins differ per printing technique. So if you tried would you just wash out the cartridge with IPA then fill with the resin? I do know formlabs would tell you that your warranty would be voided if you used a Kulzer resin. Formlabs is rolling out there denture base pretty soon.
thanks much,twalked with support, they said I COULD JUST POUR THE RESIN IN THE TANK AND NOT USE THE CYLINDER, STILL ON THE FENCE ABOUT BUYING THIS PRINTER, THANKS AGAIN
