The Materials section which shows how much of each resin had been ‘Used’ is the sum of all the prints using that cartridge including the aborted ones.
One print I aborted after a few seconds due to an accidental start and another was aborted due to a sensor error before the print started. Both these prints used up no material.
There should be a way to discount aborted prints from the Materials Used section if they did not use up any material at all.
This will allow for a more accurate estimate of remaining resin.
