I did a print of a Creature that was sculpted in Zbrush as part of Gio’s Master Class and based on concept from Carlos Huante. It is 7.5 inch tall/19cm.
Just wanted to share my results here with you all. I’m doing some small touch ups. I’ll share more soon…
Very impressed. I have experimented with Zbrush and 3d printing. was it grey resin and did you have problems with the cued resin getting very brittle after a few days,
Yes, form 2, grey resin. When first printed the resin is quite flexible, a good time to remove from the supports. Then within a couple of days it’s very brittle. I’ve dropped a print from about 6 inches on to a table top and the figure of an Abbot monk snapped off at the ankles.
Thanks Dave! I appreciate it!
It was printed in clear resin and then I did a primer coat on top. So far all the prints came out without and difficulties. This is my 3rd attempt, you can check my other smaller ones on my website: http://www.markochulev.com/copy-of-portfolio
