Clear Resin and White Resin In Isopropyl Alcohol
Hi Everyone,
I will be starting a V4 clear resin print but wanted to make sure that the clarity of the print will not be interfered with if I wash the clear part in ISP Alcohol that has already washed white resin parts. Should I clear out the Formwash everytime I use a different resin? Will any white resin get on the clear part and then cure when I put it in the UV cure? Thanks in advance.
It’s no problem to wash all the resins in the same bucket except for Rigid resin. This does leave particles on other prints.
You should do a final rinse in cleaner IPA after the soaking.
