Manually edited supports are turning out to be essential for successful prints of my models - and yet sometimes prints need further tweaks such as changing the base thickness or support height - and changing these after having made the manual support adjustments requires starting all over again - losing what is often a significant amount of work and time.
Also - as a relatively minor aside it seems there’s a bug such that changes to the default support settings such as internal-supports, base thickness and support height are lost after making manual support changes. This isn’t as much of a concern however - it’d be much more of a timesaver to add the feature rather than fix the bug…
