I love that Preform now has the ability to Import supports when you load a model into a different resin environment or change print settings. Is it possible to do the same thing when you change the Base Thickness or Height Above Base? It would be neat if the Advanced Supports dialog had a checkbox for that.
Seconded. Now that we have the support import feature, we just want more out of it
Would a sort of ‘maintain support locations’ checkbox in the advanced panel work for this? I’ve forwarded your suggestion to our software team.
Edit: This is possible currently but it’s definitely not a streamlined workflow. If you increase the base thickness and then add or remove a support in edit mode and ‘apply’, that will conserve the support locations. We’ll look into implementing a better workflow for this.
Great, looking forward to see what you all come up with!
