Castable resin and isopropyl alcohol
Hello
I’m using the castable resin (V1) for the first time on my Form 2 after extensive tests using clear resin 02. Am I suppose to rinse my castable resin print in Isopropyl alcohol before curing the piece?
Thanks for your help!
Richard
Yes, otherwise you will be left with a film of sticky non-cured resin. Good luck! I have found that wax is much more challenging to print than the clear.
Thank you!
Since I’m working on jewelry projects I was wondering if you had the chance to test the difference between the castable resin V1 and V2? I read the latter is more accurate…
