I have a part that’s like cup. the bottom inside always comes out sticky. i assume its because its upside down when curing. now that raft and supports are off could i lay it down and recur, its rigid 4000 material. thx
of course, why not?
Or you can also let it out in the sun for some time
Hello @badseed -
You can certainly cure your part twice. If you have a UV light you can spot cure the inside after curing the rest of the part, or run it for a short cycle, or just leave it under a light for a while.
I’d also recommend spot cleaning interior surfaces with a squeeze bottle to make sure there’s as little partially cured resin before the cure cycle.
Kind regards,
-Jen
