Can you add onto Dental LT Clear post curing?
So after design print and cure we have to grind to have a perfect fit sometimes over-grinding can make things rock so we’ve been adding a self curing acrylic resin to these. The bad thing is ,after Ivoclar acrylic cures, it will just slip right off with small pressure. Has anyone found anything to work to be added to resins. if any biocompatible dental methods are out there that would be great!
You could use some of the actual resin and cure it in place with a UV light. Might have to build it up layer by layer or maybe print another patch and cure it onto the existing piece. Just throwing out some ideas.
Chris
So I thought of the same thing. i got some of the resin out and got my hand light curer (dental). It did absolutely nothing to the resin
