I’ve been online and to the local chemists and can only get 99% or 70% isopropyl Alcohol. Since 90% is recommended does any one know where I might be able to purchase some or whether it is chemically posible to dilute 99% down to 90%.
Maplins is seriously overpriced. Go on eBay.co.uk and you can buy it delivered for a fraction of the cost, and a better grade, i.e.99.9% direct from proper chemical distributors.
I always avoided the higher purity alcohols because to get above a certain point they have to switch from a water to benzine process. Sure it can only be 1% but I would not want to be regularly exposing myself to it in any way.
Wallgreens has 55% 68% 72% 92% to 97% in large and small bottles. Wallgreens sells sprayable bottles in the same %. Very cheap I paid 5$ for 2 bottles and $2.45 for the sprayable one. I assume us only.
You can use 70% without issue. Personally I no longer use IPA to clean parts because it does damage them and makes them very brittle.
A product called Yellow Magic from Bradley systems and an ultrasonic cleaner seems to do the trick but will take a couple of cycles 10-15min or so lightly heated. I have been trying to get them to sell small quantities.
Yellow Magic sounds very interesting. Since i’ve got an inquisitive four year old son i’m always interested in minimize potental hazards. Is it something that can be purchased in the UK?
