How often are people changing their build chamber beds? Some of our build chambers are getting to over a year old now and we’ve started having issues with heavy print lines and other defects. Has anyone been able to successfully just change the felt seal over?
It depends on usage. You can not only change the felt seal but must change the entire bed. I only worry about it when the build chamber starts to hang up when unpacking it. You can remove the build plate and vacuum the seal and knock of any melted on powder but after a few times of doing this is will have to be replaced. Most of the times build chambers have issues is after about 750-1k hours when you need to conduct a full service on your build chambers including opening up the back and cleaning them out and greasing the lead screw.. How many hours are on your build chambers. Have you done the full service on the build chamber?
