Broken raft appears in Preform 3
The raft seems to be like those broken surfaces in Rhino when I added support myself.
This seems like something Formlabs Support and/or Software will be interested in - please file a Support request if you haven’t already. In terms of moving on with your print, does it help at all if you change the orientation slightly before generating the raft, or if you use Mini-rafts in Preform 3 instead of a regular raft?
I closed the app, reloaded the model and generated the support again and it looks good this time.
Thank you for reporting that. We’ll investigate.
What version of PreForm are you using?
3.0.2
