Brand new Form 4, splashing inside tank / printer
Hi all, I just printed on a brand new Form 4.
I noticed a lot of splashing / splatters inside the tank (see picture).
Is this normal behavior, it seems a little odd.
I printed in Black Resin V5, using supports, 0.05mm layer height, timelapse activated.
Form4 has this sequence of filling up the tank with at least 300ml-400 ml of resin minimum even when the print requires very less. This behavior was explained by @Sophia_M
The splashing is caused by mixer pushing the extra resin on to the wall of the tank so that it rebounds on the tank wall and creates a mixing motion, you could tune it down by adjusting mixer speed.
While other users have reported issues like frothing and bubbles in finished product for which the advise from the community has been to reduce the mixer speed you could benefit from this as well.
I am attaching a few resources for your reference:
Since I see another printer right next the one you have photographed, The more important question I would ask you is have you experienced the same with that printer as well?
If no then, in what way does this machine behave differently ?
Thank you for the detailed response and explanation.
I agree, reducing the mixer speed is likely going to fix it (and I will try). Unfortunately, this is not a global printer setting - so it will only apply to my prints, and not to the other users.
I can’t test the other printer yet, as I’m missing some parts but will test in the future.
You could make it a global setting for a resin by creating a custom print profile which is stored on your copy/account on preform for other users using your account to use.
Check out this article for understanding implication of Wipe Settings and other print setting parameters - Using the PreForm Print Settings Editor (SLA) | Formlabs
The above link also gives information on creating custom print profiles.
Hope this helps :smiley:
