Is better LCD resolution for the Form 4 is on the way?
Hey @DeNovix!
Thanks for your question! At this time there are no plans to change the MSLA panel on the Form 4.
Can I ask if there’s a specific project or application you’re working on that you don’t think the Form 4 is capable of handling? In designing the Form 4 we put a LOT of time into making sure that the 4K panel inside is more than sufficient for most people doing most types of printing most of the time.
Totally happy to answer any additional questions you have or to provide more details or specifics!
Hi Dan,
Thank you for the quick answer. I’m trying to make a cylinder (14mm dimeter) with threads (1mm pitch) on it and the threads are not sharp and the root of the threads are rounded more then intendent design. I tried to clean it thoroughly and I don’t think that is the problem
Thanks,
Benny
Thank you for the information! Can I ask what material you’re using and what layer height you’re currently printing at?
White V5 and I tried Tough 2000 also. The layer height 0.05mm
problem is likely not printer resolution. How did you create your STL? 4K screen is 50 micron (or better). Definitely enough resolution to create your threads.
I wasn’t aware that STL file can be adjusted and I’ll check it out. thank you!
