Best NON heat set threaded inserts (in Tough 2k particularly)
Hello All,
I was hoping to start a discussion and get some ideas from the hivemind on threaded inserts for Tough 2k.
I have had pretty good luck with tapping directly into the material (particularly for 10-32 and above) but recently had to do some fairly small, M2, holes threaded holes in a part and the tapped threads just immediately turned to powder and failed. I had decent but not perfect luck with using helical (Helicoil brand) threaded inserts in 4-40 but haven’t yet ordered anything in M2
I am currently considering three different products to see which one works best in this application but would love any other ideas or feedback you might have.
Helical Threaded Inserts, biggest problem here is I need the taps, and the installation tool which is a lot of money on something that might completely fail given the STI thread is still kind of fine and small. I did also print some with the STI thread already in them and while a bit tight at 4-40 that did work.
McMaster-Carr
Self Tapping Threaded Inserts (Trisert)
I think these are going to work well but haven’t seen any specific information on their use.
Screw to Expand
I also think these will work well but I don’t know if the Tough 2K will hold them tightly enough after being unscrewed several times?
Any other threaded inserts I am missing that I should try? If I can maybe I will do some testing with the leftovers after I finish the project I need these for. Thanks!
For reuse I would personally always recommend Helicoils. Screw to expand inserts have worked well for me in the past as well, though I haven’t used them nearly as much…as long as the use case temperature is pretty stable I would expect them to perform fine.
We use self tapping rolling screws a lot as well as screw to expand or press fit inserts. Helicoils are great but sometimes a pain to install.
I swear by the screw-to-expand M2 inserts for Grey V4.1 on our Form 3B having previously run into a lot of issues with Triserts cracking parts (though Tough 2k should have much less of a problem). Some prints using them are regularly dis-/reassembled for about a year without problems; they’re reprinted due to wear on other features.
Helicoils would probably be best in theory, but I don’t want to pay for that installation tool when I can just press these in on any vise or arbor press.
I’ve found that a modeled hole diameter of 3.275mm with a 0.2mm lead-in chamfer works great for my setup, but you could probably get away with a smaller diameter if you want them to be Really snug.
Helicoils are great! I’ve used them in Tough 2000 for a while now.
