I have a large part that I’m splitting to print. I have used the resin to adhere the other resins, but am not certain that, because of opacity, that is going to work for the flexible resin… granted it’s ideal, because it’s “flexible” also.
… can a Formlabs person chime in and recommend the best flexivble-to-flexible adhesive?
I have used a RapidFix UV light todo the cure for flexible (both in flexible to flexible and flexible to white) with great result. Usually I end up doing two passes. One to just put things together and second pass to make sure it stays put. I think RapidFix is a little under the necessary UV length so I use my curing chamber to remover the stickiness left behind after the light cure.
