Automatic resin 'homogenizer'
Might have already been suggested, but how about a ‘mixer’ function? (Lower the build platform and then run the peel cycle continuously to mix up the resin in the tray.)
My printer sits idle for days on end, so pigment is always settled out when I go to print. No matter how long I manually mix after scraping the bottom of the tray it seems my first print or two always have poorly cured sections and are much more prone to failure than later ones. After a couple prints though, it seems like the pigment is fully mixed and things start working better. I’d like to be able to run that ‘machine mix’ cycle for maybe 5-10 minutes vs. standing around to do it by hand (which doesn’t seem to work as well anyway) without needing to make a sacrificial print in the process.
I have the same thing but what I do is empty the tank through a filter and with the scraper clean the tank. The haze so far always clears off. Then I refill my tank. Doing this between EVERY print ensures I have good mixed clean resin. So far I haven’t had any failures other than my own fault through model error or orientation.
Adding a mixing cycle won’t scrape the bottom nor filter the resin. It will also add more mechanical workings which means more things can go wrong and add to the cost of the machine.
o wow… that was 12 years ago… I would love to have a mixing function. Working with alumina without a mixing function is a pain.
Is form labs considering any of the suggestions? since this is 12 years old and there is no comment nor is this feature implemented…
Is there an alternative software for form labs available.
Modern Formlabs printers already come with a mixer. There is no really good way to implement this on older printers
Then perhaps I misunderstood the post. I need a function to move the mixer.
On my Form 4 I can not make the mixer move e.g. 10 min before starting the print. This would be necassary to start the print automatically. Now I have to do it manually every time.
This would be super easy to implement and would save a lot of time and hassle.
No, that’s also implemented with the preheating function that you can turn on in your printer settings.
Once you have preheating enabled, it will auto mix and auto heat when everything is ready in the printer (build plate clean and locked, mixer ready, resin tank inserted) and the printer is on. Sometimes it doesn’t work when you think it should, but you can kickstart it by just telling the printer you removed and added back the build plate - so it can be started manually, sorta
DM me if you have any trouble, happy to help
Thank you very much for the explanation! I tried it and was not able to move the mixer…
Which model do you have?
Does it look like the preheating function is doing anything?
I have the Form 4. Yes I think the pre heat function is starting but the temperature is already at the set point so it is not mixing… that’s my interpretation.
Hm, something feels wrong. The preheat function should mix a few times automatically even when the temp is already at temp or above. Mine mixes every time
So just to confirm, you have preheating turned on in the configuration page of the actual printer? Like on the little LCD screen, not preform, right?
thanks a lot for the help! I will reach out to the support team.
This really seems to be a feature that hasn’t been implemented yet. Please, dear Formalbs team, include this in the next release!
Thanks for all the help! It woks now perfectly!
