"Auto-scaling" in preform for Fuse1+30W
Please consider adding a feature in Preform which “auto-scales” or shrinks/grows each XYZ dimension individually of each individual part according to part size + what or which zones of the build chamber is in or spans across.
This is a great white paper, extremely helpful. Would be great if Preform could use that data to “auto-scale” or “auto-size” the XYZ dimensions individually according to where in the build chamber the part is + part size with the target dimensional accuracy being +/-0.3mm across all XYZ axis. The Z axis tolerance is the biggest changer, and the goal is to have an automated way to change the dimensions of each individual part accordingly to always be in the +/-0.3mm range for XY and Z no matter where in the build chamber, in one click.
Thanks for reading this, and any consideration.
Hi! Thanks for writing in! I have forwarded your request to the responsible team for evaluation.
