Hi All,
Jory has suggested that adjusting the resin tank level yourself will void your warranty - I take strong exception to this, because it’s very easy to do.
The Form1 solution for “levelling” is utterly elegant - in that it’s simple and very forgiving. It uses springs, and so you only need to be “good enough” in adjusting them, there’s no need for micron precision and obsessive spirit level checking etc…
Also adjusting them is completely reversible and can do no lasting harm to your Form1. See my rant on the subject in this thread https://support.formlabs.com/entries/38561208-Testfile-didn-t-print-succesfully-Base-plate-too-thin. I really hope Formlabs will change their tune.
In the following video, I explain how easy it is to adjust the resin tank level, if your part bases are coming out too thin when the resin tank springs are too high.
Or - perhaps your bases are coming out close to spec thickness, but you’re getting strange extraneous goopy flakes on your prints, or maybe your parts won’t adhere to the build platform - in which case it may be that you need to increase the height of the resin tank springs.
It’s my longest video I’m afraid at 14 and a half minutes, but I wanted to thoroughly refute Formlabs assertion that only they should be adjusting resin tank springs, and show just how easy it is, by first “breaking” my form1 and showing you the prints that come out, and then fixing it.
So the first half of the video explains how to adjust the spring tension nuts - and the second half shows a couple of bad prints after I “maladjust” the springs, followed by a good print after correcting the springs.
http://www.youtube.com/watch?v=CB9OeCxT04U
Alternatively - if you don’t have the patience to watch a few minutes of video, here’s how you do it.
1) Find a small magnet
2) Remove the upper cover+top half of Form1 case (they come off as one unit) - by unscrewing the top 4 hex screws from each side of the Form1 (careful with the black ones, it’s very easy to round out the heads - so only do them back up finger tight), two hex screws under the cover hinge, and also the front and back cover panels. To remove the front panel you need to undo two more hex screws under the base of the Form1 at the front.
3) Plug the Form1 back in and use the magnet on the top right of the front panel to fool the Form1 into thinking it’s cover is on and shut - and load and confirm a print.
4) Wait until the build platform has fully descended to Z=0 - and the resin tank has come back up (tic-tic-tic) and the laser has just started. Then remove the magnet to pause your Form1
5) Now your Form1 build platform and resin tank are mated together in the starting position, and so you can adjust the resin tank spring nuts to match the resting height of the resin tank, to the starting position of the build platform.
There are machine screws through the centre of each of the springs at the four corners of the resin tank frame - you adjust the height of these springs, and hence the height of the resin tank at rest, by tightening or loosening the nuts.
Tightening the nuts, reduces the height of the springs, and the rest height of the resin tank, loosening them of course does the opposite.
If the resin tank springs are too high, then there will be clear screw thread visible between the nut and the black coated steel of the resin tank frame, and what you want to do is tighten the nut** until it’s just about touching the frame, **for example if you could almost slide a piece of paper between the nut and the frame, then that’s spot on.
Conversely - if your parts are coming out with thick bases but goopy flakes attached, or if parts are not attaching to the build platform at all, and one or more of the nuts is obviously tight against the resin tank frame, then back it off until you can see screw thread between the nut and the frame, and then tighten it back up again as above.
That’s it, easy as pie, and zero risk - you can’t hurt* your Form1 doing this.
Kevin.
*PS - when I say you can’t hurt your Form1 doing this, that’s with the caveat of the black hex screws. I did round out the head sockets and had to dremel slots in them to use them. So be careful!!
