I got three consecutive mushroom like part failure. Does anyone here experienced the same?
My printer is a replaced printer. The previous one had the famous adherence problem, e.g. the printing part was not sticking to the build platform. But now, it seems over sticking. I got the replacement printer after a lengthy trouble shooting and waiting for the replacement. With the replaced printer, I have gotten almost 90% successful rate on 6-7 batch of initial printing, but yesterday got failure like mushroom shown in the attached photos.
Before each printing, I used a paint strainer to filter the debris. After the second failure, I changed the resin tank to a brand new one, then I got the third exact same failure. In each failed printing, there are a large area of debris sticked on bottom of resin tank. All of these three printing are the same model with PreForm generated orientation. Now I am trying to print it with clear resin to see if the problem is about that grey resin only. But I already see the mushroom like support stick out of the main body. Clearly, resin and resin tank is not the cause.
Did anyone else experience the same situation before? Optical problem? Thanks a lot!
Wish not suffering another two months replacement process … Hope it be a little bit reliable…
PS, a ticket has been submitted (37832).
