I would be nice if the form 2 could print the base at 100 or 200 microns, and then switch to 25 microns for the object.
This could reduce the print time significantly!!!
That sounds like a great idea. And it can continue at the fastest available resolution until the first layer of the actual object, which by default it’s another 5 mm at the best available speed!
