I know I’ve seen this request before. Not sure why this has not been implemented yet, except that it probably got buried under other things. Seems like it would be pretty simple and would speed up the print considerably for 25um prints. Ideally, it would print all the way up to the first layer of the model @ 100um, then switch to the selected resolution. Is there some technical reason that this cannot be done?
          that’s a really good idea!
I would ad that it should be not at 100um but at the highest available resolution because clear v2 has a 200um option. Also because future resins can be held to their standard if they can print at higher or lower resolutions then 100um.
Either way this is a really good idea and I would love to see this implemented!
