Dental model base resolution change
Just wondering is it possible to change the resolution to the fastest print option just on the beginning base of the model and then then have it go into a higher resolution for the actual model?
It’s already the case at least with all the resin I use. If you look through the layes in Preform you can see that the first layer of your model is always layer 51 despite the resolution set in preform.
