FormWash Strange Noise
My FormWash makes noise once up to speed sometimes. Here is a video of the problem. Seems similar to this post?
Suggestions?
Hi @bibbinator,
I am very sorry for the late reply on this, but if you have not already opened a ticket with our Support Team, that would be your best bet to get a timely resolution!
I got a ticket opened and resolved some weeks ago. Thanks
That is great to hear, thank you for letting me know. Have a great weekend!
What was the solution if you can share? In case others get the same noise
I got two solutions to the problem:
  1. I organized a replacement unit to be sent.
  2. Meanwhile, I emptied the tank, removed everything and set it up again and noise disappeared for a while. No actual knowledge of what causes it, but I think it’s something to do with the mechanism alignment with the magnets. Manually moving the mechanism back and forth seems to allow something to realign and fix the problem (for a while at least).
But because of #1 I don’t have too much time experimenting with #2.
