I would like to use the supports from the form 2 in the form 1 +, is there any way?
Different hardware, different version of preform, no way around it I guess.
The peeling process is different from the Form1 to the Form2. I would guess the supports are different in order to address those printer functional differences.
Why would you want to? You use less resin. Are the thinner supports failing on the Form 2?
