Using printed parts for electrochemical cell
In our research center, we plan to print some cells for electrochemical tests. We are concerned that if any of the printed parts are exposed to a NaCl or 1% HF solution, there may be a release of chemicals from the print into the solution. This is critical for us because even trace amounts of elements, at the parts per million level, can affect our experimental results.
Thank you in advance for your help,
Best regards,
Bahram
Hi @bahram_vn,
Thank you for reaching out! I would recommend contacting our Support Team for specific questions in regards to chemical compatibility. They may be able to provide you with a more detailed answer, especially given the level of precision required for your application.
