Is it possible to use NextDent C&B resin in Form 1+ printer to print dental crowns?
As we know for surgical guides formlabs have Dental SG resin which is part of the NextDent SG resins / http://nextdent.com/products/sg-surgical-guide/
So if we put the NextDent C&B resin into tunk will it polimerise under the forlabs laser light???
FL’s resin is undoubtedly tuned for the Form printers. A non-FL-optimized resin will probably work but not quite as well. You can always just buy a small bottle and try it. But… Why don’t you want to use the resin FL specifically developed for your printer?
If you can optimize more nextdent resin like NextDent C&B it will be great.
Imagine:
We do preparation on patient’s teeth for bridge. Then we scan the mouth with digital intraoral scanner. Now we have stl model of the prepared teeth. We generate bridge in dental cad/cam software like exocad or 3shape.
And finally we print the bridge from biocompatible resin NextDent C&B in Form 2.
So we cemented it into patient’s mouth.
Done. For less than 20min.
