Larger tough V5 parts come out great but smaller parts under 20mm adhere partially to the build plate and then the rest adheres to the resin tank and I wind up with only a very thin outline of the base. I’ve tried increasing the base thickness to 2.3mm and it worked for some but not for others. I’ve tried on several printers, so its not the printer. This did not happen with previous tough versions. I can print the same parts successfully with 2mm base thickness in Clear V4 or Grey V4. Is there a trick to get these to print?
Thanks for the troubleshooting you’ve done by iterating on the base thickness and trying a few machines. Our support team is going to be best suited to help out with this, and one of our members will be reaching out over email to help out.
