Tough Parts Tacky
Currently using TOUGH RESIN for a FORM 2 printer, and all the parts are coming out tacky after curing in the uv cure chamber for an hour.
Do I need to rinse with clean iso propyl alcohol every time?
Cure longer?
After the cure chamber, I thought I would dip it in th alcohol, and then rinse with water right away??
Too tacky for sanding…
I even use a paint brush to wash the parts thouroughly…
Any
Especially for Tough Resin, it’s important that you use relatively clean IPA. This is much of the reason we recommend soaking in one container for a few minutes and then finishing the part in another. You might try soaking in the first container of IPA for 10 minutes or so, then remove the part in soak in the second for another 10 minutes. Make sure that the second bucket is relatively clean as this is important for removing all of the excess resin from the part.
