I’m investigating a repeatable dimensional issue on a part printed on a Formlabs Form 4-generation printer. Unfortunately, I cannot share photos or CAD files due to an NDA, but I can describe the geometry in simplified terms.
The part has a cylindrical outer contour and a solid base approximately 3 mm thick. Above this base, internal recesses reduce the local wall thickness, while remaining ribs provide structural support. The CAD model specifies a constant outer diameter throughout this region.
The actual defect is a sudden, slight reduction in the outer diameter at the height where the printed cross-sectional area changes, particularly where the solid base transitions into the recessed section with walls and ribs. On the places where the ribs are however, the intended diameter is correct. This creates small steps or bands around the exterior rather than a smooth, continuous cylindrical surface.
The description in this post seems very similar, particularly the visible perimeter line where the solid base transitions into the walls-only section.
One thing I would check first is the part orientation and whether suction forces could be involved.
Is the part printed directly on the build platform? Is it hollowed out, and if so, have you added drainage holes to prevent suction effects?
If the part is printed directly on the platform and has a symmetrical geometry, I would pay particular attention to the size and position of the drainage holes. Even if PreForm does not flag any suction issues, the holes may still be too small to allow sufficient resin flow during the peel cycle.
This can generate pressure differences and additional forces during peeling, potentially contributing to the ring-shaped dimensional deviations you describe.
That said, I would consider this a hypothesis to investigate rather than a confirmed cause, as the transition from a solid base to thinner walls and ribs could also be related to changes in local stiffness and peeling forces.
yes the part is printed directly on the build platform, another orientation isn’t possible with the material I’m using. I found a picture which I am allowed to share that shows the defect:
The suction cups definitly might be an issue, but I think the main reason would be the sudden change in crosssectional area. I’am currently trying my luck with some changes in the peel and squish settings.
First thing I would do is enable cup mitigation if you haven’t already. But any abrupt change is cross sectional area tends to exhibit these artifacts. There might be ways to reduce it by adjusting peel, squish or irradiance but the simplest is to angle and support it rather than print direct on BP
