Here is a tip you won’t get from Form Labs due to liability issues. That said if you follow this advice you do so at your own risk. A really easy way to detach parts is to use a widow scraper razor. This is like a utility knife, but with a straight razor about 2 inches wide that can be extended and retracted. The razor goes right under the part with way less effort. Of course you run the risk of needing stitches if you aren’t careful, but it works way better than the putty knife.
