The material is a ceramic filler in a photopolymer vehicle.
This allows you to print a shape of ceramic… but it’s not unlike greenware in ceramic slip casting…
A fragile structure of dried mud.
Ceramic only becomes the porcelain or kaolin like material you associate with the term when it is fired at temperatures that essentially FUSE the clay particles so they fuse into a glass like structure.
This is what makes ceramics able to take the very high temperatures they can withstand.
In casting metal… you have 4 basic options… you can mold in sand- which as quartz/feldspar can already take high temperatures… you can mold in neoprene, or platinum silicones…but those materials can only take relative low melting point metals like pot metal, pewter and such. You can do a lost wax mold in a foundry investment- which is a plaster like material that is filled with high temperature resistant fillers… or you can take a wax casting and DIP it in a vat of a ceramic slurry, repeatedly, building up a thin “shell” of ceramic clay (filled with sand or other refractory agents)… let the shell dry- then Bisque fire the SHELL- which burns out the wax and pour the hot metal into the shell mold.
Because the shell is only bisque fired… it remains pourous- allowing the gasses in the metal to vent out directly thru the shell wall, and after it cools you literally jackhammer the shell off the metal casting.
This medium is meant to allow you to PRINT a shell directly, without dipping it and drying it laboriously and enable you to print more complex shell voids than can reasonably be made using wax masters.
However… the ceramic shell process as currently used has a VERY LOW shrinkage factor.
1.5- 2%… which compounds with the metal and wax shrinkage for a total dimension change of 4% from original master- to final metal casting.
In knowing this factor- I can sculpt a master exactly 4% overscale and know it will shrink to my target dimensions. This is critical in, for example, fitting a cast metal part to, say, a cast Concrete structure, because the concrete is NOT gonna shrink at all.
Or in this case… fitting a cast metal part to existing parts of known dimensions.
In normal ceramics, the shrinkage can be very high, especially in the porcelains, because they are fired so hot.
Someone throwing a vase or coffee cup knows it’s gonna shrink a lot.
But in ceramic shells used in foundry operations, the ceramic slurry is heavily filled and alternated with layers of sand… it just doesn’t shrink nearly as much.
In jewelry casting, refractory investments do not shink at all, rather they every so slightly expand… and a ring master needs only be 1.5 - 2% bigger than your target ring size.
But I can not reasonably cast a custom ring to the size I want if I can’t nail down the shrinkage I am going to get to within a half percent or so.
I think a schedule of settings and conditions, including a curing and a firing schedule should be compiled so that folks wanting to use this media can design their patterns with confidence.
