Hi all,
I have a broken FormCure in stock. The temperature displays shows me unbelievable values. After a quick disassembly of FormCure, it seems to me that the temperature sensor inside is broken. I already checked a PT1000 sensor without success. Do you know which temperature sensor is assembled in FormCure? If yes, please give me a clue.
Hi @TorstenRehwald,
Good question! While I don’t have specifics on the Form Cure temperature sensor, I would recommend reaching out to our Support Team in order to narrow this down further. Although I don’t believe this sensor is a user-replaceable part, Support could inquire about the sensor or at minimum discuss replacement options for the Cure.
