Anyone wanna take a guess?
Have not been honestly running it much this past month and she started failing consistently after one successful print. Now we are on print number 4 with three different chambers failing shortly after the preheat and initial printing.
It is “sink holing” again around the perimeter of the chambers and under dosing from the Left to Right pass of the doser.
It is doing this with a +5 doser offset.
This would be totally confusing to me…if I literally did not just go through this a few months ago with the same exact thing happening.
Last time I saw this, it was totally confusing as I had thought all three chambers went bad at once from all the leaking powder…
Anyone wanna take bets that when I pull the entire back off the printer… that we are going to see a loose coupler on the Recoater motor?
This was the culprit last time. That simple coupler gear broke loose on the motor shaft making the Recoater roller cause all these same things.
Bout to let it cool down before I rip it apart to confirm.
If this replacement Recoater motor and coupler are broken loose again…my next question is why?
I probably have had only a few dozen prints done since the last time this happened and it was replaced…
Posting this because this took a solid month to troubleshoot the first time it happened with a Formlabs rep here on scene checking and troubleshooting all the chambers before figuring out a simple loose coupler on the doser motor caused all these issues.
The actual fist thing Formlabs support suggested when I sent the reports were to tear the back off the printer and check the doser motor coupler… so I assume this happens a lot and wanted to check with other Fuse users out there.
For those that have not experienced this, hopefully this saves you some time if you see these failures and under dosing/sink holes.
