Being able to see the angle in which you rotate objects would be vert useful
No kidding as it would be a good way to make sure clam-shell parts will fit together as designed.
I still want the ability to see edges of a model, especially when editing support touch-points.
And having it snap within 5deg would be nice too. I usually use the orientation menu to type in the angle that I want it to rotate the part because I’m not able to drag it and know the actual angle.
