Stepping through layers to add/remove supports is a powerful ability, It would be nice if PreForm would remain on the same layer when editing or applying changes to the support structures.
I will second that, and also it would be nice if the slicer did not slice backwards in the editing mode, as I at least find that very un-helpful.
Or even add a method to type in the value on the slider so that you do not have to have a steady hand when you have 2000 sections.
Both valid points; although I actually like the upside down slicing when editing supports. Might be nice to have an option for the direction of slicing, retention of layer position when bouncing between modes, and a field to type layer position.
