hello guys
I have bought the form cure and will arrive next month I have the grey resin if I have the resin cured is it possible to place the object in the sun or will it warping
hello guys
Once a part is fully-cured, it won’t warp further. Warping after printing tends to be caused by the final photo-polymerization reactions finishing and once this has occurred, a part won’t warp further. Excessive heat can still cause the part to deform but if the temperatures are anywhere near what we’ve been having in Boston, you should be good to go
If the part is thin and you leave it in the sun then the heat will warp it
oke thank you for your answer
