Resin tank none, Form 2 doesn't recognize the resin tank
It could be that the plug on the bottom of the carrier plate has become unseated.
You don’t want to remove the carrier plate if your unit is still under warranty, but if it’s not, you should read this thread all the way through before removing the plate or you may not be able to get the plate levelled:
