Resin Tank Cleaning
What is the best way to clean the interior section of the resin tank?
After I pour the left over resin out, do I need to rinse it? Should the tank be free of any left over resin from the previous build?
Unless you know you are not going to use the printer in the next few months you can leave the resin in the tank to use in the next print.
As bill mentioned, unless you have a specific need to remove the resin from the tank, I’d probably leave it just for simplicity’s sake.
Is there a reason you’d like to clean that surface? Just asking out of curiosity as maybe I can point you in the right direction :slight_smile:
this is my first time printing via resin, so I just wanted to know the best way to maintain/preserve the resin tank. if or when the leftover resin in the tank hardens, I assume I need to clean it before the next print?
Hello,
I actually have the same question. I would like to experiment with different types of resins and also try out several colors, but I only have a few resin tanks.
Unless your printer is left in strong sunlight with the cover open, the resin left in the tank will not harden.
Hello, I’m also looking for an answer to this question. None of the responses have actually provided an answer so far.
When I switched resin from Grey to Grey Pro I followed these steps to clean the tank.
https://support.formlabs.com/s/article/Cleaning-After-a-Failed-Print-Form3?language=en_US
Haven’t been so lucky. Today I just discarded two trays. Couldn’t clean them.
Washed a third, but the window is very cloudy - almost white. Use white resin 4000v1 most times. It’s becoming very expensive to use this printer. Very dejected today
Hi @VIDENC0,
Sorry to hear about your poor experience cleaning tanks. For future reference, I wanted to pass along our guide for Inspecting and cleaning resin tanks (Form 3/Form 3B). If issues persist after attempting to clean, please feel free to share a few photos of the tank with our Support Team for a closer look.
At Formlabs, we recommend filtering the resin in your tank after any failure that you’re not 100% confident that you’ve captured all of the debris from. Reusing a tank with a different material is not ideal, but it is possible. Anyone looking to do so can check out our article for Reprogramming a resin tank (Form 3/Form 3B) for steps on how to maintain resin tank quality while switching resins.
Note: Tanks should never be washed with a solvent of any kind, only squeegeed and drained. Solvent will damage the inside of the tank.
Any one looking to learn about cleaning resin tanks and filtering resin should check out our video for cleaning debris in the resin tank for both the Form 4 and Form 4L.
While this video is Form 4 generation-centric, the practices are applicable across all of our SLA printers. I hope it helps!
