Resin of different versions
After recent updating resin had additional versions.
Tell, what will occur if I try to print with gray v2 resin on v1 resin?
The new resin settings have to do with the new formulations our Materials team developed. The new resins require different exposure settings that are not optimized for the v1 resins.
You would likely see reduced print quality and a higher print failure rate if you use an improper material setting.
