In a few threads, I’ve seen people discussing that you occasionally get different results if you choose a different material in the printer settings.
Is there any furhter information available about what the printer does differently if you choose ‘gray’ over, say, ‘white’ or ‘clear’?
~ Haje
Each setting is for the type of resin you use. Grey for grey, white for white, and clear for clear.
Thank you, but that wasn’t really what I was after
I was wondering, specifically, what the printer changes between the different colours. Does it use different exposures? Does it slightly change the layer thickness?
~ Haje
