Repeatably Printing
Whenever I re-run jobs, I have to move the part around so that it doesnt glaze a particular area. Is there an easier way to do this? Would be nice if the printer could do this automatically… Thoughts?
Buy an LT tank, problem solved :wink:
I own allot of LT tanks, and have mixed feelings on this. They also will glaze over repeated uses in the same spot, but I admit that it takes longer. The biggest frustration I have with them, however, is when the inevitable failed job occurs, you have to be extremely careful not to damage the layer. In some cases, you simply cannot get the stuck material off without causing some sort of damage to it. The standard tanks, however, rarely get damaged this way.
