I have attempted to print this model four times, each with different positions and rotations using the Anycubic slicer, and I also tried Lychee with automatic support.
Each time, I’ve encountered the same issue, particularly at the corners, as shown in the pictures. When I place the model parallel to the bed, the corners lose their attachment, becoming rounded and loose with significant holes. I tried positioning the model at one corner and tilting it up to 30 degrees, which resulted in a better outcome than placing it parallel. In this orientation, the corners were still rounded, but there were no holes or detachment.
Slicing Parameters:
- Layer Thickness: 0.05 mm
- Normal Exposure Time: 3.60 s
- Off Time: 0.50 s
- Bottom Exposure Time: 30.00 s
- Bottom Layers: 5
- Anti-alias: 1
- Z Lift Distance: 8.00 mm
- Z Lift Speed: 6.00 mm/s
- Z Retract Speed: 6.00 mm/s
Could these issues be related to my slicing settings, or is there another problem I need to address?
