I am having problems printing at a finer resolution then 0.1mm. I am trying to test a prototype part before tooling goes into effect and the feature is very small so the fine resolution is needed. Please see attached images of failed print at 0.05mm. Would like to do 0.025mm but that never has worked. Any suggestions on how to get it to work at finer resolutions. As you can see 2 of them failed, but also the on supporting structure failed to print for all of them.
Can’t see your photos
Updated links, thanks for letting me know
You need more supports
