Hi Eduard
The reason for importing objects with the inclination already done, it is for several reasons.
In my tests, when I created automatic orientations, the parts are very inclined, and that makes that spent more resin, and secondly the duration on each print will longer. moreover, steep parts got errors in below areas because it created many stripes. and thus, the piece out much better. the pieces are manually inclined 15 degrees and 10 degrees respectively to each side
All this reasons are because if you print one object there is no roblem, but i need to print 25 or 30 each, and this more time (+ 3 hours plus each) and more resin ( 1/3 more ) its a lot if you multiply by 25 or 30 and this is less money for me.
I did not know you could import multiple objects at once, if I knew I could import more than one, but one by one.
I’ll try to do it on separate objects and bring them once
Thanks for your tips
