Printable Parts for Formlabs Printers (SLS + SLA)
Our R&D team designed and curated a collection of helpful .form files for your printers—like cartridge clips, mixer tools, and more—so anyone with a Formlabs printer can download and print for free.
Check them out here: Printable Parts for Formlabs Devices
Includes:
Form 3/B and Form 4/B :form_4:
  • Form 4 Exhaust Plug: A removable air plug provides access to the print cavity for active air handling.
  • Form 4 Tool Caddy: The tool caddy on top of the Form 4 holds the parallelism shims a 2.5 mm hex key, and a 4 mm hex key. Designed to be printed on a Fuse 1 generation printer.
  • Form 4 Build Platform Mount: Build platform mounts hold build platforms when they are not in use.
  • Form 3 Build platform mount: Told build platforms on a wall/board in your work area when they are not in use.
Fuse :fuse_1:
  • Vacuum cleaning attachment for hopper: Two versions designed for cleaning powder out of a Fuse 1, Fuse 1+ 30W
  • Vacuum cleaning nozzle: Designed for use when cleaning powder out of a Fuse 1 generation printer
  • Cable gland wrench: For when replacing the hopper trough or buffer trough RTD or heater on the Fuse 1+ 30W.
  • Build chamber lead screw cleaning tool: Designed for use when [cleaning and relubricating the lead screw in a Fuse Series build chamber.
  • Fuse Sift Funnel: Replaces the flat fresh powder hopper lid included with original Fuse Sift units. Print and install the Fuse Sift Funnel to more easily, especially for when using bagged powder. Formlabs designed this part to be printed on a Formlabs SLA printer with a material like Tough 1500 Resin.
  • Fuse Blast: Waste hopper funnel: Makes it easier to empty the waste hopper on a Fuse Blast. The funnel directs the waste into a bag, jug, or other container.
Do you have ideas for new parts we should design? Or something you designed for your workflow that others might find useful? Share it below to keep building this library!
Two more helpful designs for Fuse organization, created by one of our Application Engineers who prints daily on Fuse:
  • Delfin Vacuum attachment holder
  • Fuse USB holder for those that use direct upload
Printer: Fuse, Fuse 1+/30W
Material: Nylon 12
Use: Fuse Organization
Delfin Vacuum Attachment (1).STL (4.5 MB)
Fuse USB holder (1).STL (1.6 MB)
And an alternative Vacuum Nozzle designed by a Formlabs teammate:
Straight Vacuum Nozzle Attachment
Printer : Fuse, Fuse 1+/30W
Material : Nylon 12
Use Vacuum nozzle attachment
Formlabs_Fuse_Straight Vacuum Nozzle.stl (5.1 MB)
What material is the Form 4 exhaust plug printed in?
Tough 2000!
