Whenever I use the menu buttons FILE EDIT VIEW HELP, after clicking a command, Preform crashes.
I had the same issue. Uninstall and reinstall did it for me. Rare bug wich i think will be adressed in the next update.
Bende Aynı Sorunu yaşadım. Güncelleme yaptıktan sonra sorun ortadan kalktı. umarım sende düzeltebilirsin
Attempted that, and also a limited startup. still crashes. I only use menu ribbon for units changing. So now I just do that in Nettfab.
Check in controllpanel so you don´t have multiple Preform installed. I noticed yesterday that i had 2 version installed. Might be a conflict.
Hi @magicwandstudio ,
It is also possible that if you are using an external display that there is a conflict; sometimes we will see issues where the buttons are inactive or can’t be seen in the display resolution, so that might be worth looking into. If the problem persists, I would advise reaching out to our Support Team.
