When I edit supports on a model which have “custom” support settings (0mm z-compression and no raft) PreForm do not use the old settings but those I had configured when clicking edit.
This was pretty confusing as I had forgotten about how I had it setup.
It would be great if PreForm could check if the model in question already have supports and if so ask is I want to load those or use what I had setup in the supports panel.
